Trailer Wiring
Old 11-22-2008, 12:57 PM
Jabez's Avatar
Default RE: Trailer Wiring
I can also vouch for that. I bought the converter at Walmart and spliced it in via the side wall access. If you google it there is a complete set of instructions with photos on the web.
Old 10-17-2011, 09:55 PM
elrocha69's Avatar
Originally Posted by xengineguy
Has anyone tried a "valley" powered converter on a disco 2 ?? From reading their info,it seems the converter uses a seperate power wire to provide power for lights. The origional rover wires just supply trigger signal to the converter. 3 models up to 15 amps. Priced from 30.00 to 55.00 depending on model. Might be a better option than the cheepy converters,and less$$$$ than rover oe.
I used a powered converter. Now I have a trialer with a 7 pin flat connector and have to figre that one out since it has brakes and the break away setup.
Old 10-18-2011, 06:23 AM
drowssap's Avatar
gruehle
07-27-2020 09:10 AM
PedroNole
07-02-2007 07:54 AM
MiniManiac
05-21-2007 08:55 AM
PedroNole
06-28-2005 12:50 PM
Quick Reply: Trailer Wiring
