Tranmission fill port
Old Mar 22, 2009 | 09:29 AM
Wcarter's Avatar
Default Tranmission fill port
I am trying to add transmission fluid to a 2004 Land Rover Discovery. I can find the plug on the transfer case where you can add fluid, but I cannot seem to find the plug on the side of the transmission where fluid is added. Any advice. I'm sure there is a seperate fill plug for the transfer case and the transmission but maybe I am wrong?
Old Mar 22, 2009 | 09:41 AM
Street Wolf's Avatar
It's on the side of the transmission pan. Look again, it's very easy to spot.
Old Mar 22, 2009 | 09:55 AM
Filling the tranny is a 2 step process, fill as much into the apn as you can, reinstall the fill plug, start the engine, shift drive to reverse 3 times, put back in park and with the engine still running go add as much ATF as you can get in, usually around 5 plus quarts total.
Old Mar 22, 2009 | 10:48 AM
lipadj46's Avatar
Do yourself a favor and get a gear oil pump from Napa or wherever. The one I got was $8 and it beats the alternative.
danari
Jun 19, 2012 10:49 PM
pilsner
Jan 13, 2011 08:56 PM
mydisco03
Feb 15, 2010 11:13 AM
Disco Alan
Apr 21, 2009 06:22 PM
Roveroh
Jan 15, 2008 01:08 PM
