tranny in Park, tapping noise when brake applied
ok, so my D2 is running and I'm parked, I tap the brake to put it in Reverse, and I hear a noise in two places simultaneously. in the left side by the turn signals, I hear what sounds similar to the turn signal noise... and at the same time I hear and feel a light tapping sound from under the shifter... like something is poking up from under the shifter.
only happens when it's running, in Park, but not when moving
no idiot lights are lit on the dash... but the ultra gauge is showing pending code 1668. maybe unrelated
any ideas?
thanks
scott
any ideas?
thanks
scott
so I have done some searching still doing more... my brake lights work, though I think the bulb in the passenger side brake light is out... looks like if i keep driving it, the solenoid can get stuck and lock the shifter
is this correct... pull up on the shifter **** and the **** will come off, and then pull the black shift **** housing up to reveal the solenoid? can cleaning the solenoid give good results? or replace it
thanks again
scott
thanks again
scott
I would not worry about it.
Better to worry about if what you are about to eat is healthy.
Read the contents label and the calorie count.
OK, so if that relay failed..
You are in drive.
It fails and you can't shift out of drive..
You are stopped anyway.
and the Brake pedal is pressed.
Just turn off the key.
If it fails in Park, then you can' leave where you are.
Of course, a meteorite could come down and hit the Rover.
But, I would not worry about that either.
These relays have a MTBF which is very large. Probably thousands of clicks more than the rover will last as a collection of working parts.
Statistically, you are safe.
You are in drive.
