Trans Fill/CheckPlug free flowing
Old Aug 29, 2010 | 09:20 AM
Jupe209's Avatar
Default Trans Fill/CheckPlug free flowing
While checking the transmission fluid level I removed the fill/check plug and fluid came gushing out. I did have a clean catch pan under it and caught all of the fluid. Looks like about 4 quarts came out. I thought that it should only trickle out if it was at a proper level. How do I get the fluid back in and keep it from spilling back out? Is there undue pressure from somewhere causing this? Any thoughts?
Old Aug 29, 2010 | 10:56 AM
Well, now you get to do a fluid change. When checking the fluid level, you start the engine, shift drive to reverse 2 time, go back to park and with the engine RUNNING, you either check or add fluid to the tranny.
Old Aug 29, 2010 | 11:29 AM
Jupe209's Avatar
Aha, should have checked it while engine was running. Headed to auto parts store now.
ArlowCT
Sep 8, 2014 09:42 PM
EstorilM
May 28, 2010 09:17 PM
Disco Alan
Apr 21, 2009 06:22 PM
tbesselman
Oct 10, 2007 09:26 AM
DeepBlueWater
Sep 27, 2007 07:33 PM
