Trans Temp Light
Old Dec 31, 2007 | 10:12 AM
Default RE: Trans Temp Light
I agree, since you light comes on at start up it is not overheating, it is either a bad switch or a short.
Good luck,
Old Jan 2, 2008 | 08:24 AM
ch4699's Avatar
7th Gear
ORIGINAL: ch4699
2000 Disco II. temp light is on, but it is the trans temp light. Vehicle seems to run fine and does not over heat. Any ideas on what the problem could be...
Old Feb 5, 2008 | 11:21 AM
ch4699's Avatar
7th Gear
where do you add trans fluid to these vehicles ?
Old Feb 5, 2008 | 11:48 AM
okdiscoguy's Avatar
There is a fill plug on the tranny. You have to use a lube pump to fill. It has to be checked warm and running. Should be a 2mm bead of fluid running out. The full write up is on here somewhere. Do a search...
Old Feb 5, 2008 | 12:32 PM
ch4699's Avatar
7th Gear
thanks...where do I check the fluid.. I must have spent 20 minutes looking for a dip stick or something similar....thanks again
Old Feb 5, 2008 | 01:27 PM
The fill plug on the pan.
tbesselman
Apr 28, 2011 10:04 PM
Sunny side auto
Apr 10, 2011 08:00 AM
bamarover
May 21, 2007 08:24 AM
bamarover
May 18, 2007 09:33 PM
97DISCOIDAHO
Sep 9, 2006 11:04 AM
