Trans temp light on today
Old Apr 9, 2011 | 11:20 PM
Sunny side auto's Avatar
Default Trans temp light on today
I was on the free way and the red trans temp light went on. I also got a code for incorrect 4th gear ratio. I will service trans on Monday. I wonder if the lock up is failing and over heating the trans ?
Old Apr 10, 2011 | 08:00 AM
The gear ratio fault code is usually a failing MAF.
The trans temp is usually a bad temp sensor.
Service the trans by changing the fluid and filter and see if the temp light comes back on, if so replace the sensor.
Buy a can of MAF cleaner and clean the MAF following the directions exactly.
If the code comes back after all else then replace the MAF.
tbesselman
Apr 28, 2011 10:04 PM
ch4699
Feb 5, 2008 01:27 PM
bamarover
May 21, 2007 08:24 AM
bamarover
May 18, 2007 09:33 PM
97DISCOIDAHO
Sep 9, 2006 11:04 AM
