Trans Temp Light On - wont go away
Old 10-25-2019 | 07:17 AM
AussieRover111's Avatar
Default Trans Temp Light On - wont go away
Changed transmission fluid + transfer case + diff fluids front and rear. Replaced transmission cooler sensor with new. Cleaned trans case sensor with MAF spray. Red light still comes on. Am afraid to drive it. Not sure if the trans fluid is filling the cooler. What could be causing this light to come on?
Old 10-25-2019 | 08:05 AM
Sandman614's Avatar
A bad temp switch. I just replaced my stock one in the cooler with a glowshift gauge. The temps never read above 180F
Old 10-25-2019 | 10:29 AM
Best4x4's Avatar
Or you have a wire that’s nicked & grounding out
Old 10-25-2019 | 01:49 PM
Sandman614's Avatar
Does the light come on and stay on as soon as you turn the key or does it come on after you've been running for a little bit
Old 10-27-2019 | 05:39 AM
After running. 10 min. On the highway. Normally over 3 RPM's. I dant understand this.
Old 10-27-2019 | 05:41 AM
Temp switch on the cooler? Ya I replaced that with new. There is another temp switch on the trans yea?
Is the whole trans cooler supposed to be full or just up to where the lines are?
Old 10-27-2019 | 05:42 AM
Where?
Old 10-27-2019 | 09:07 AM
Sandman614's Avatar
That circuit has 2 temp switches, in the cooler and in the transfer case. If you replaced one it could be the other. When the light come on park and unplug each sensor to see which one turns the light off.
Old 10-28-2019 | 04:09 AM
I'll replace that sensor on the transfer case. It could be the problem. You know what the correct part number is for that? I hope this solves it.
Old 10-28-2019 | 11:33 AM
Sandman614's Avatar
Before throwing money at it, unplug it to see if it makes the light go out, then CHECK your T-case fluid level. I do not know the part number right off.
