Trans temp sensors
Old May 29, 2014 | 03:44 PM
dusty1's Avatar
Default Trans temp sensors
Could someone point me to where to/which one to buy. I found the one for the trans cooler for $43 at ab. That sound right?
I am having trouble finding the one on the transfer case. Anyone know where to find?
Had light a while back, took off sensors and cleaned them up. Worked for a while, but that b*+cH came on today.
Is there a mechanical set up that I can use? I would prefer that. Anyone done it?
Old May 29, 2014 | 04:01 PM
Motorhead1's Avatar
With the light on, unplug one sensor at a time and see which one turns the light off..Worked for me in the past. Check transfer case fluid too
Old May 29, 2014 | 04:04 PM
ralphobell's Avatar
Rovers North call Zack. Tell him you want a better deal!
SWITCH OIL TEMPERATURE LT230, RND460, PRC7984 - Rovers North - Classic Land Rover Parts
Old May 29, 2014 | 04:06 PM
ralphobell's Avatar
Also AB has them much less expensive....tell Zack to price match.
Sender Oil Temperature Transfer Case (PRC7984 Same Fit As Part # PRC7984 ) - Land Rover sending units from Atlantic British
Old May 29, 2014 | 04:16 PM
ralphobell's Avatar
You can get this from L8 and tap a temp sensor in it.
Lucky8 Llc. - Take the road less traveled...
Old May 29, 2014 | 04:39 PM
Dane!'s Avatar
Your exhaust is in the way on that upgrade.
Old May 29, 2014 | 04:45 PM
ZGPhoto's Avatar
Originally Posted by ralphobell
That's an aftermarket, ours is genuine
That being said, of course I can get one cheaper for you.
Old May 29, 2014 | 05:51 PM
dusty1's Avatar
Only, problem is that it will come on for like one minute then off and intermittently and sporadically
Old May 29, 2014 | 06:03 PM
dusty1's Avatar
Thanks all. Couldn't find that little dude. Might try to figure out a mechanical set up first, but now I can find one when I fail at that
Old Jul 8, 2014 | 02:12 PM
dusty1's Avatar
So my light came on today
So after replacing both temp sensors I have not had the light come back on, until now. I'm about 180 miles away from my house and it happens. I got out and did the quickest test that I could think of which was to unplug the leads to the transfer case. Light promptly went out.
My question is, if you take away the possibility of the wiring error causing the light, what would cause my transfer case to get hot? Low oil is not the issued. However, I do use the sender port as my fill level. Could I possibly have to much oil?
My vents are not clogged either.
Transfer case is supposed to be on the low end of the worry about list.
Any thoughts?
