transfer box change out
Old Mar 20, 2010 | 09:46 AM
vandev's Avatar
Default transfer box change out
Hey all, Anyone ever chnge out a transfer box at home? Sorry i ask but my laptop is out for service at HP and i dont have my RAVE available. Just currious on time and difficulty. It's for a 2004 SE7 that the transfer box is whining on deceleration. I have located a few transfer boxs but would like to save on labor. Have jack stands and tools. Have done most work on my daughters 2000 SE Disco and my old RR 4.0 SE. Any advice well taken. I have a transmission guy threw a friend of mine that would changeout for under $300.00. It's a friends friend. Most places are quoting $500.00 - $700.00 to do the work.
Thanks Chris
Old Mar 20, 2010 | 09:49 AM
Are you sure it is the t/case and not your front drive shaft? When they start to fail, they can make noise and or vibrate when speeding up and go away when slowing down.
Old Mar 20, 2010 | 10:00 AM
vandev's Avatar
Default Hey Mike
Hey Mike, I though it was to but i took it to a friend of mine who is a Ex Land Rover Service manager and we drove it and then he put it on the lift with the tires off the lift. Ran with the wheels running and you can hear right from the transferbox. SHifts from H to L to locked no problem. It only make the whining grind sound when you take your foot off the gas when you go over 30 miles an hour. Its like a turbine sound or somthing. If you touch the gas it goes away or when you go below 20 miles a hour. I bought the truck and then took back when i heard the noise. They said they would refund my depoit but the truck is in 99% condition and i got a great deal... yea, the grinding noise. My Land Rover guy showed me that the cross member was taken off as the bolts wher cut. He said maybe someone serviced it and left it oil low maybe. It had a couple of drips on the botom. He said i should replace it. The place i got it from has offered to get there trannsmission guy to do the labor at about half of what my local indy rover place quoted. I would love your feedback on this ..
Thanks Chris
Old Mar 20, 2010 | 05:13 PM
Danny Lee 97 Disco's Avatar
Did you try draining and refilling t-case to see if the whine remains after fluid change?
Old Mar 20, 2010 | 08:24 PM
vandev's Avatar
Default next step
I will try on monday when i go back to wher i bought the truck from... i think it's a long shot..
thanks for the reply though....chris
Old Mar 20, 2010 | 11:50 PM
csbd's Avatar
To answer your original question, yes it can be done at home if it turns out yours needs to be replaced. The rave instructions are easy to follow. First be aware the transfer case is very heavy. The big problem I had was that I couldn't get the truck up high enough with jack stands to get the transfer case out and in under the frame while on my floor jack. I had to wrestle the transfer case off and on the jack while it was under the truck.
Oh, and don't skip the step where it says to drain the oil from the transfer case, you'll take a bath in gear oil otherwise.
Old Mar 21, 2010 | 09:07 AM
You almost need a lift to get it high enough. I hate wrestling with big heavy stuff in confined spaces. You almost need to be a Zen Contortionist to get to some of this stuff.
Old Mar 21, 2010 | 09:14 AM
Also check and replace the front drive shaft if it hasn't been done yet or it only has 1 grease fitting, other wise you may have it fail and it can damage the tranny also.
madpony123
May 26, 2015 02:05 PM
collin Barrows
Aug 28, 2011 07:13 AM
ant996
Defender
Sep 14, 2006 05:03 AM
esblandrover
Sep 4, 2005 07:48 PM
lugo35
Apr 21, 2005 05:03 PM
