Transfer Box - replacing front bearing
Old Jan 4, 2022 | 01:26 AM
buggame's Avatar
3rd Gear
Default Transfer Box - replacing front bearing
Hi all.
About to take delivery of a D2a. The previous owner tells m the front bearing in the transfer box needs replacing....little bit of slop an a whine.
He tells be it is a straight fwd job, about an hour and no need to remove the box from the vehicle.
I have watched a few videos. The rear bearing looks as he describes (very easy and straight forward)....but the removal of the front is not entirely clear.....and I suspect might be a bit more involved.
Could someone please advise and perhaps point me to a decent video.
And/or a decent (online) manual.....will likely need one now!!
TIA
Old Jan 4, 2022 | 02:07 PM
Extinct's Avatar
Download the factory manual (RAVE) from sticky at the top of the forum. I have not heard that one bearing wears out before the others, that would seem unusual in my view.
Old Jan 4, 2022 | 02:38 PM
Richard Gallant's Avatar
@buggame Before going through all that drain and replace the fluid transfer case and diff oil with a good quality gear oil. Then grease the driveshafts. The bearings do go, but whine and slop is usually oil and dry drive shafts.
Old Jan 4, 2022 | 04:09 PM
buggame's Avatar
3rd Gear
OK. The plan was to drop all fluids (except perhaps the transfer case) and replace. Grease all shafts. Will see if that makes a difference. Am yet so see just how much movement there is. Dunno. Just getting prepared.
Is there an easy way of dropping the grease out of the swivels??
Old Jan 4, 2022 | 06:50 PM
mollusc's Avatar
Get yourself a copy of the RAVE before you start changing fluids. The fill procedure for the autobox is a little unusual.
No reason not to change the t-case fluid.
Old Jan 4, 2022 | 07:03 PM
buggame's Avatar
3rd Gear
Thanks. I have done a bunch of searches for the RAVE manual......cant for the life of me find it!! Maybe its staring me in the face!!
Would you mind adding a link?
Cheers
Old Jan 4, 2022 | 07:22 PM
gecko951's Avatar
Here ya go: https://discoii.wordpress.com/resources/
danburnand
Nov 4, 2019 01:19 PM
woodchip2bert
Jun 16, 2018 01:30 AM
Landroverowner
Mar 1, 2017 05:20 AM
Mountainman
Defender
Apr 14, 2007 03:24 PM
markp
Feb 8, 2006 05:48 AM
