Transfer Case
Old Sep 3, 2013 | 04:26 PM
Braxton's Avatar
Exclamation Transfer Case
I'm having my transmission and transfer case replaced with a used lower mileage set. My mechanic just called and said the transfer case has 2 extra electric connectors on it. Will this transfer case work on my 2002 Disco 2? I got the transmission and transfer case off a like model.
Thanks for any guidance!
Old Sep 3, 2013 | 07:15 PM
floundering's Avatar
Does "like model" mean same year? Replacement T-case might have CDL and that would have a connector for the Diff lock warning lamp on the dash. Have your mech take a pic and upload it.
Old Sep 3, 2013 | 09:44 PM
jfall's Avatar
I second that. The two wires are for the switch to say you are in CDL.
Looks like you are getting a better transfer case.
What is the donor vehicle year?
Old Sep 3, 2013 | 11:18 PM
SWAINROVER's Avatar
Default t case
Beware on these used t case they will all be bad close to 100,000 miles and dont belive a junk yard that sales them as good unites .Had two go bad in the past 20,000 miles so i rebuilt the next one. These have eight bearing in them take it to a shop that works on t case and rebuild it 250 for parts plus labor.
Old Sep 4, 2013 | 02:50 AM
Mel Morales III's Avatar
5th Gear
I am going through the same thing. I have a2000 discovery that need tranny and trasfer case replaced. I found a 04 with 60k miles on it. Is that compatible? Please let me know as i am worried about this. Thanks in advance.
Old Sep 4, 2013 | 07:51 AM
Mel, an 04 case will work with your truck, will you also be getting the shift linkage?
You will need to get a little creative with the wiring because the 04 has a different shift solenoid, but you can work around pretty easily.
Braxton, what you need to find out is what year that t/case came out of. You only want a G2 t/case from a 99, 2000, 2001 or a 2004, do not use one from a D1.
When you say you got it off a like model, doesn't tell us what year. Are you wanting the CDL, if so don't forget you will need a D1 or an 04 shift assembly.
Old Sep 4, 2013 | 08:54 AM
5th Gear
Hi mike, thanks for the reply. The unit i bought came with the shift linkage. How about the tranny? I heard the 04 tranny is longer because its a 4.6. What do i need to do with the wiring? Can i use the old shift with this new one? Thanks as always.
Old Sep 4, 2013 | 10:02 AM
Do you have a 2 cable shifter or one with mechanical arms like from a D1?
The difference in length is not worth worrying about.
Old Sep 4, 2013 | 12:08 PM
Braxton's Avatar
Thank for the replies. My question is can this transmission and TC be installed without connecting the other 2 connectors?
Old Sep 4, 2013 | 03:44 PM
3 responses ask what year disco the tranny/t-case came from. See if you can find out and perhaps someone can answer your query...
