Transfer case high/low signal to SLABS missing
Old Dec 24, 2009 | 09:51 PM
Scott R's Avatar
Default Transfer case high/low signal to SLABS missing
Title says it all, according to SLABS I'm not in LOW on the transfer case and thus cannot use HDC. I've been looking through RAVE wiring diagrams only to find nothing. I know the pin that supplies the SLABS computer with the input, but that's where it stops.
Anyone know why my transfer case is not supplying the low signal to the SLABS?
Old Dec 25, 2009 | 07:26 AM
Urban Panzer's Avatar
Most likely a duff switch on the transfer case, its located by the side of the front output housing, worth checking out the connections and maybe remove the switch and test it.
Attached Thumbnails Transfer case high/low signal to SLABS missing-high-low_switch.jpg
Old Dec 25, 2009 | 10:34 AM
Scott R's Avatar
Thank you! will give that a try in a bit.
Old Dec 25, 2009 | 03:43 PM
Scott R's Avatar
Fixed! thanks for the picture it solved this. The switch is directly above the drive shaft and it has a gray plastic weather-pack connector. I took the connector apart cleaned out the muck, shot some dielectric grease and it works now.
gmad
May 27, 2015 12:11 AM
LRLawyer
Mar 17, 2014 10:22 PM
omarica7
Mar 11, 2014 08:12 AM
onewingman
Feb 23, 2014 01:03 PM
TRIARII
Oct 11, 2011 08:15 PM
