Transfer Case is History (Need Advice)
Old Dec 12, 2013 | 04:14 PM
srockrae's Avatar
Default Transfer Case is History (Need Advice)
Major grinding and clanking noise turned out to be the transfer case as confirmed by my local LR mechanic. He wants $900 in labor plus part to swap it out. He said it did have proper fluid levels in it. Truck has about 110k so I guess it was just its time. My questions are as follows:
1) Should I go used or rebuilt?
(It is beyond my capabilities so if the used one goes bad I will be out the labor even if the salvage yard warranties the part)
2) If used, where could I source one?
3) If rebuilt, I found the one from Roverland Parts for $1,300 after shipping. Is that the best source for rebuilt. Looks to me by the website they are doing a lot of inspecting but no new parts. Is that really a rebuild????? Discovery Transfer Cases
4) Is $900 reasonable for labor to swap that out?
Any help would be greatly appreciated. As luck would have it, the engine blew up this time last year and I threw $5k at it for a used one. Its just my Land Rovers way of saying MERRY CHRISTMAS!
Old Dec 12, 2013 | 04:18 PM
ZGPhoto's Avatar
Ashcroft will be the best source for rebuilt. Ashcroft Transmissions - LT 230
Old Dec 12, 2013 | 04:29 PM
srockrae's Avatar
Do they ship to US reasonably from UK? Any idea of how long that takes?
Old Dec 12, 2013 | 04:32 PM
ZGPhoto's Avatar
We can get them for you, but you may be better off talking to Justin at Lucky8, he deals with them quite a bit more.
He'd probably ship it for you.
Old Dec 12, 2013 | 07:40 PM
acg's Avatar
acg
This is a great deal... and you will get CDL which did not originally come with your 2003:
https://landroverforums.com/forum/pr...linkage-63628/
P/S. I am not affliated with the seller.
Old Dec 12, 2013 | 08:44 PM
roverdrj's Avatar
I just did mine. New one with labor ordered from Atlantic British was 2400 installed in an 04. 12000 mile warrantee. Labor seems about right. Best of luck
Old Dec 13, 2013 | 05:52 AM
drowssap's Avatar
used new fluids and seals
Old Dec 13, 2013 | 07:56 AM
srockrae's Avatar
Which seals would I want to replace?
Old Dec 13, 2013 | 07:57 AM
srockrae's Avatar
Trying to contact him now. I am assuming that if I want to do the CDL shifter and cable later that would be fine. I am correct?
Old Dec 13, 2013 | 08:50 AM
ZGPhoto's Avatar
it would be fine, but it'll be a good idea to have it done at the same time, as you're already in there.
