Transfer case- how do you get fillplug out? hits brake drum backplate...
Old Apr 24, 2009 | 12:50 PM
JBEGIN's Avatar
Wink Transfer case- how do you get fillplug out? hits brake drum backplate...
no way that a 1/2" ratchet and a 3" extension goes in there... sorry spike but i think yer smokin crack...
Old Apr 24, 2009 | 01:00 PM
Try without the 3" extension, or use a swivel joint, move the e-brake cable out of the way, it is snug but it will work.
Old Apr 24, 2009 | 01:14 PM
jycsalas's Avatar
You can try this
http://www.discovery2.co.uk/transferbox_oil.html
or using the 1/2 ratchet by its self in this position as in the picture.
Attached Thumbnails Transfer case- how do you get fillplug out?  hits brake drum backplate...-t-case-oil.jpg
Old Apr 24, 2009 | 01:33 PM
JBEGIN's Avatar
yeah ill try the ratchet upside-down trick... will let ya know how it goes.
Old Apr 24, 2009 | 01:47 PM
LOL. Not crack, meth.
I just did it a couple of weeks ago and I could not find my extension, no problem without it, move the parking brake cable, loosen it with the ratchet, remove ratchet then remove by hand.
Old Apr 24, 2009 | 02:33 PM
JBEGIN's Avatar
okay... Meth. Lol
yeah gonna have to do that, actually i broke it loose and can get the ratchet out, then have to remove it the rest of the way by hand, its just time consuming. i was gonna cut down a 1/2 in square head and weld the cutoff to a scrap piece of iron and bend slightly at the end if i cant get it by hand... i can make something up but dont think I'll have to.
if it can be done im sure I'll get it, one way or the other.
Old Apr 24, 2009 | 08:41 PM
grussell's Avatar
I just changed he fluid in my T-Case a few weeks ago and this tool worked great. I just moved the E brake cable out of the way and it fit perfect.
Attached Thumbnails Transfer case- how do you get fillplug out?  hits brake drum backplate...-transfer-case-fluid-change-005.jpg
Old Apr 24, 2009 | 09:08 PM
llPANCHOll's Avatar
I use the Ratchet to back it out just enough that the Ratchet doesnt get trapped in there, then I use a pair of pliers to gently coax it out untill its loose enough to unscrew by hand..
Old Apr 25, 2009 | 12:49 PM
JBEGIN's Avatar
Didnt hurt the threads turning that plag with pliers? im sure the breaker bar will work fine, i havent been into it myself, neighborhood oil changin' guy down the street is...
Old Apr 25, 2009 | 02:45 PM
llPANCHOll's Avatar
I have a set of curved skinny vise grips..
Similar to these..
and GENTLY was the key word here.. I brought it out as far as I could with the 1/2 inch drive and then used them, now the threads are cleaned up as I've been checking the fluid level once a week as I have a leaky rear output shaft seal, I can loosen it with my hand once I back it out a bit with the 1/2 inch drive..
