Transfer Case Inspection Plate - RTV?
Old May 10, 2022 | 12:16 PM
cvhyatt's Avatar
Default Transfer Case Inspection Plate - RTV?
My inspection plate is leaking pretty bad. I put some blue devil in it a while back , but the leak is back and time to fix it right. My question is, should I use the RTV ultra black or the grey? My research is providing me with conflicting information.
Thanks!
Old May 10, 2022 | 12:44 PM
Harvlr's Avatar
Personally I’ve used the Ulra Black and Grey interchangeably. I’m not an expert on this but I haven’t had issues with either of them.
Old May 10, 2022 | 12:53 PM
Best4x4's Avatar
Right Stuff is what I like to use. Stuff works very well IMHO
Old May 10, 2022 | 06:50 PM
Brandon318's Avatar
Is the factory gasket just Hylomar?
Old Jul 20, 2022 | 07:29 PM
redrover75's Avatar
Question on this, I replaced my fluid, pulled out the bolts bc I thought the cover may be leaking. The cover was stuck on after pulling the bolts so I left it alone. It looks like I have a leak from one of my bolts. If I recall correctly they were not all the same length, does anyone have an idea of which bolts go where? It think that may be the source of a leak.
Or, I could be completely mis-remembering and the bolts are all the same.
Thanks
Old Jul 21, 2022 | 07:39 AM
SundayFunday's Avatar
Is your intermediate shaft O-ring leaking?
Old Jul 22, 2022 | 07:03 AM
redrover75's Avatar
Default Leak
yes, I do think it is leaking. But it also looks like there is a leak around the bolts. If I recall they are different lengths and I may have put them back in the wrong order.
Old Jul 22, 2022 | 08:50 AM
your likely to crack the casting or strip the threads if you were to install incorrectly.
If you don’t have an order soon, I am just about to pull my inspection plate off this weekend.
Old Jul 22, 2022 | 08:58 PM
redrover75's Avatar
Thanks, i would not have done that, so I suppose that is not the issue. Must be the o ring, need to figure out that repair. I was hoping to not have to drop the whole thing.
eskiltell
Dec 1, 2016 04:42 PM
eskiltell
Dec 1, 2016 04:17 PM
archaeology_student
Aug 2, 2014 09:43 AM
aftermath431
Oct 17, 2013 07:53 PM
melmanc55
Sep 24, 2006 12:30 PM
