Transfer case inspection plate Torque and bolt sealant?
Old Jul 28, 2014 | 03:46 PM
aftermath431's Avatar
Default Transfer case inspection plate Torque and bolt sealant?
Ok I used Permatex Gear Oil RTV Sealant for the inspection plate and the blue loctite on the inspection plate bolts. but my torque wrench is to long to use under my disco so I had to guess at the 18 LBS torque for the bolts. I just hope it doesn't leak.
Old Jul 28, 2014 | 05:49 PM
Jared9220's Avatar
Originally Posted by aftermath431
I have to reseal the inspection plate on the transfer case because I did not put any sealant on the inspection plate bolts and now they are leaking. can someone till me what the torque is on the inspection plate bolts and what I should use on the bolts to keep them from leaking gear oil? also if any knows the sequence on what order to tighten down the bolts that would help.
Here is most of what you need:
1) T-Case Bottom cover.pdf
2) The bolts get 18lbf.ft
3) I follow this guide to find a substitute for the Land Rover sealants. So use Loctite 243.
STC50550 : Loctite 5900
STC50551 : Terostat 8586
STC50552 : Loctite 243
STC50554 : Loctite 648
STC3811 : Hylomar 101 (Amine curing RTV silicone sealant - engineering grade)
STC4404 : Hylomar 607 (Oxime curing RTV silicone sealant adhesive)
STC4600 : Hylomar 3400
4) The RAVE does not indicate a pattern to tighten the bolts in so use a typical cross pattern. I work from the middle out and then recheck everything after the first torque down. (right click on the picture below and pick open in new tab, then open the new tab and click on the picture to zoom in.)
Old Jul 28, 2014 | 07:55 PM
me6067's Avatar
Has anyone removed the upper transfer case inspection cover without taking out the transfer case? It would appear to me that the clearance is too tight to remove the bolts as they hit the transmission.
I am also resealing my lower inspection cover in the near future, is it necessary to remove the cross member? Any advise on removing it, even with a big breaker bar the bolts seem to be frozen. If i sent up snapping them... can you insert a new nut in behind?
Sorry to have thread jacked a little...
Old Jul 28, 2014 | 08:20 PM
Jared9220's Avatar
Like you I am slowly replacing all of my leaky gaskets on my T-Case. I just replaced the rear inspection cover gasket without removing anything and now I am moving on to the side cover plate. I believe it is the same upper inspection cover that you are talking about.
I have looked at the cover closely and I think that you can remove all but 1 of the bolts with the T-Case in place. I think I might try and remove all of the bolts I can and just loosen the one bolt right up against the trans pan. I think I might be able to swing the plate down and apply the new gasket with it still attached. (This is only a guess at this point though. It might not work)
Use liquid wrench on the frozen bolts and let it sit.
Some people have had luck using oil stop leak so that might be worth a try before you start unbolting things.
Old Jul 28, 2014 | 08:39 PM
me6067's Avatar
I have some white Shepperd/blue devil stop leak here that I intent on putting in once I reseal the t-case inspection covers as good measure for future leaks and main seals. Let me know how the side cover goes.
Old Jul 29, 2014 | 02:57 AM
Default what about sealing near end of bolt heads?
Thanks for the help Jared your information is going to make things a'lot easier. I have one more question. What about the end of the bolts does anyone use sealant around the ends to keep them from leaking our is there crush washers on them? since the sealant only goes around the bolt holes on the inspection plate and the threads of the bolts. last time I did this I got a few leaks coming from the inspection plate bolts because I didn't seal them with anything. I found out that there is a relatively new sealant for use with synthetic gear oils called Permatex 81182 Gear Oil RTV Gasket Maker. I think i'm going to try this stuff if I can find it in the auto store.
Old Dec 20, 2014 | 11:07 AM
Default fixed!!
(update) Iv'e tried the black RTV sealant on the inspection plate in the passes and it still leaked. This time using Permatex gear oil RTV sealant and a little lock tight on the bolt treads along with some blue devil for good measure. It hasn't leaked a drop since repair. So I would say if you have a inspection plate leak this is the way to go. Just do your best to torque the bolts to spec's.
Old Dec 22, 2014 | 09:35 AM
5kcstq's Avatar
FWIW. I tried 3 times to get my inspection cover sealed with Gear Oil specific RTV to no avail. Eventually built a paper gasket and used RTV and that finally did the trick. Definitely would advise using a real gasket to avoid doing the nasty job twice.
Old Dec 22, 2014 | 11:02 AM
dusty1's Avatar
for best results in this method. use compressed cardboard. large corrugated cardboard is a no go.....it will not last. (a suitcase of beer will completely do a couple of motorcycle engines)
*take the piece, that needs a gasket, and cover it with a thin layer of oil.
*lay the piece onto the unfinished side of the cardboard and press
*remove the piece and you now have an outline of the surface area.
*cut with a razor blade(scissors will compress edges)
*drill or punch out bolt holes (leather punch or paper hole punch works on small ones)
*sandwich
Old Dec 22, 2014 | 12:26 PM
Lowest Bidder's Avatar
Neat! One other trick is to place a piece of 8½x11 sheet of cardboard of the type used for document covers in a copier, then place the part that needs a gasket on the copier glass. Press COPY. Cut out using an x-Acto.
Cheers!
Georges
