Transfer case move vs. drop question
Old Aug 23, 2021 | 08:23 AM
dswilly's Avatar
Default Transfer case move vs. drop question
So I have a leak that I am nearly 100% sure is coming from the front input shaft seal pictured below. My question is if the transfer case can be slid back vs dropped to replace this. I have a extra transfer case and know these things are very heavy from moving it around. So can the driveshafts be disconnected and the box unbolted from the transmission, then slid back far enough to swap the seal or does all of the upper connections (sensors/ diff lock / shifter) need to be removed as well?
Old Aug 23, 2021 | 08:26 AM
Alex_M's Avatar
My bet is going to be you'll just want to drop it. The output shaft of the transmission is fairly long, so you'll have to pull it back quite a ways anyway, and seating the new seal in place would be a massive headache under the truck.
Old Aug 23, 2021 | 08:35 AM
mollusc's Avatar
100% agree with Alex. You won't be able to move the case back far enough to clear the shaft without disconnecting most/all of the attachments, at which point you may as well lower the thing to the floor.
Old Aug 23, 2021 | 08:55 AM
dswilly's Avatar
Good thoughts. I was guessing that would be the case. Since I have the extra t case I might swap seals in that and have ready to go. Thanks for the info.
Old Aug 23, 2021 | 09:02 AM
mollusc's Avatar
Do you know the years and mileage on both cases? Later years (I believe 2003-04) have different internal structures that supposedly make them quieter. And of course there's the CDL.
Old Aug 23, 2021 | 09:58 AM
Best4x4's Avatar
You can unbolt the transmission output shaft and remove it. That can allow you to drop the TC straight down once off the dowel pins.
Old Aug 23, 2021 | 10:00 AM
dswilly's Avatar
Both are 04 cases with CDL. Mileage is 179k on the one in the truck although it looks like it has been resealed or redone at some point. The other is about 135k and pretty clean, no leakage etc.
Old Aug 23, 2021 | 10:04 AM
dswilly's Avatar
Interesting. Would that be the #5 bolt here? If so how is it accessed with transfer case still in position?
Old Aug 23, 2021 | 10:16 AM
mollusc's Avatar
Same question here!
Old Aug 23, 2021 | 12:17 PM
dswilly's Avatar
On the subject of transfer case in/out. If one was to recondition a T case what would be considered prudent for redo on a working case?
A. Seals
B. Seals and output bearings
C. Seals and all bearings.
I would love to do C. for the experience but might be more than I can bite off at this time.
