Transfer case move vs. drop question
Old Aug 23, 2021 | 12:31 PM
Extinct's Avatar
Bearings hardly ever wear out absent running it low on oil. Seals shoudl be enough. Don't forget the center shaft seal which is normal what is leaking.
Old Aug 23, 2021 | 01:49 PM
dswilly's Avatar
Originally Posted by Extinct
Bearings hardly ever wear out absent running it low on oil. Seals should be enough. Don't forget the center shaft seal which is normal what is leaking.
Would the center shaft be what they refer to as the intermediate pin in the diagram below? That one I guess can oval out the case on the front side. Both mine appear to be leak free.
Old Aug 23, 2021 | 02:34 PM
Best4x4's Avatar
You remove the round plate on the back of the TC (PTO Cover in diagram above), remove Transfer gear set and you are looking right at that #5 bolt. Remove it and out comes the transmission output shaft. Making for a very effortless TC removal job. That and removing the entire Ebrake assembly makes it a very straight forward job.
Old Aug 23, 2021 | 06:33 PM
Extinct's Avatar
Yep, that's it. O-ring seal at the front gets hard and brittle over time, leaks. Put new o-ring on, slather it with hi-torque silicone (gray stuff), and put it back in. Tight nut another 1/4 turn and let her rip.
Old Aug 24, 2021 | 10:01 AM
dswilly's Avatar
Hi Extinct, Thanks for the info. As for the center shaft removal. Is there any trickery to this? Youtube videos make it out to be fairly complicated to get reset with preload etc.
Old Aug 25, 2021 | 05:23 AM
Extinct's Avatar
You can of course reset the preload if you desire, however if you re-use the existing nut and turn just an 1/8 to 1/4 turn past the original staking point you are essentially coming back to the original preload. When the preload is set on the original bearings it is based on zero wear new bearings, I assume yours have 100k+ wear on them so a small amount of additional preload essentially compensates for that.
DakotaTravler
Sep 6, 2022 04:59 PM
huggi
Jul 24, 2021 03:56 AM
Kenso
Oct 28, 2014 09:05 PM
rfitterer
Jun 3, 2014 11:29 AM
TOM R
Apr 26, 2014 09:29 AM
