Transfer case Neutral light/buzzer stay on while in low
Old Dec 19, 2014 | 06:00 PM
Discomini's Avatar
6th Gear
Default Transfer case Neutral light/buzzer stay on while in low
I just installed a D1 CDL in my '01 DII. Everything went well and appears to work. However, when engaging low, the transfer case neutral light/buzzer stays on until I put it back in high. Is this normal? Should the light only come on while in neutral? FYI- I know low is engaging.
Thanks for the help.
BTW- I never got the light before I installed the CDL. CDL works fine and the red CDL light comes on and off as it should.
Old Dec 19, 2014 | 08:37 PM
dusty1's Avatar
Sounds like your truck thinks you case/switch is not telling the truck/computer that it's all the way in gear. is the shifter hitting or being obstructed by the d1 setup? Linkages pushing all the way?
Old Dec 20, 2014 | 06:01 PM
Discomini's Avatar
6th Gear
It's working as if low is fully engaged. But you are right, a signal is being sent thinking it's not engaged all the way.
Thanks
Bobcat9024
Mar 29, 2022 03:36 PM
Black01D2
Apr 24, 2015 06:55 PM
lordmorpheus
Jun 13, 2012 05:11 PM
urq
Mar 2, 2012 04:17 PM
aerokurt
Mar 2, 2007 12:01 AM
