Transfer case not engaging 4 high all the way?
Old Jun 7, 2019 | 03:29 PM
originalpy's Avatar
Default Transfer case not engaging 4 high all the way?
Hey guys, does it look like my transfer case isn't engaging 4 high all the way? It shifts into 4low fine but it doesn't seem to go into 4high all the way.
When I first got the truck it would not shift into neutral or 4low and the shop removed the lockout solenoid to get it to shift.
I also have a whining at speed when I'm on the throttle on the highway that I suspect is coming from the t-case. I'd like to replace it with one from an 04.
Thoughts?
https://drive.google.com/file/d/1GBL...w?usp=drivesdk
Old Jun 7, 2019 | 03:50 PM
dgi 07's Avatar
Old Jun 7, 2019 | 03:51 PM
jastutte's Avatar
if you are moving at highway speeds then you are in 4 high.
the transfer case has 4 high, neutral and 4 low.
Old Jun 7, 2019 | 03:53 PM
originalpy's Avatar
Yeah I mean I'm def in 4 high but am I allll the way in or does that not make any sense? Just doesn't feel like it clicks into it and there's a lot of play as you can see.
Just the position of the handle looks higher than others I've seen.
Old Jun 7, 2019 | 03:55 PM
jastutte's Avatar
are you afraid it will pop out of gear into neutral while you are driving?
i did just see your other post about the transmission shifter and there is a possibility you have something small keeping the T-case shifter from seating properly.
Old Jun 7, 2019 | 03:57 PM
originalpy's Avatar
I'm just wondering if its mechanically sound and engaging all the way - the whining I have I think is the gears on the t-case but was hoping maybe it was something to do with the shifter that could be remedied. Not sure why it looks that way. I dont have another pic handy of a D2 without CDL to compare.
Old Jun 7, 2019 | 04:02 PM
jastutte's Avatar
i have an '04 with the locking diff, so i think mine sits at rest a little different. hell, these are Land Rovers, so even the trucks that rolled off the assembly line before and after yours may have T-case shifters that rest differently.
i had a whine from the Transfer case for a while but switching to a synthetic gear oil eliminated it. could be that yours just needs a refresh. then again, some will tell you that a little whine is nothing to worry about.
Old Jun 7, 2019 | 04:05 PM
originalpy's Avatar
I changed the fluid recently - the whine is so obnoxious on the highway.
Old Jun 7, 2019 | 04:28 PM
Red5's Avatar
Turn the ignition on but do not start the truck. Shift into D and see if you can move the lever from H to L. If no, then you should be fully in H and the solenoid is locking it there as it should and all is well. Although, my solenoid is on the shifter and I think yours is on the top of the T-case so it may behave differently than mine.
Regardless, I don't think that would be the cause of the whine. Did it just start? Is it the same on or off of the gas?
Old Jun 7, 2019 | 05:41 PM
originalpy's Avatar
Solenoid has been removed. When i bought the truck it was not shifting into 4 low (stuck in 4 high).
The whine is only when I'm on the throttle.
Old Bertha
May 6, 2019 04:11 PM
bradsexton
Feb 16, 2018 08:34 AM
LRJtech
Nov 23, 2014 02:00 PM
Lord Wert
Mar 27, 2013 06:50 AM
ajh
Oct 5, 2007 07:01 PM
