Transfer Case - Output bearings
Old Nov 3, 2014 | 11:25 AM
ralphobell's Avatar
Default Transfer Case - Output bearings
On the transfer case output bearings front and rear, are the bearings pressed on the shafts?
Old Nov 3, 2014 | 03:08 PM
Lowest Bidder's Avatar
Yes. Remove the flange. Remove the seal and circlip, and the shaft will come out with the bearing. You will need to convince it to come out with a slide hammer puller, but it will come out.
caymandrew
Jul 8, 2013 03:24 PM
hhalimi
Apr 18, 2012 10:42 AM
wheelgarage
Feb 21, 2012 11:39 PM
EstorilM
Oct 11, 2011 08:13 PM
ljdiscovery
Feb 15, 2010 10:44 PM
