Transfer case replaceable parts
Old Apr 14, 2012 | 11:36 AM
SolbergFanBoi's Avatar
Default Transfer case replaceable parts
Hey all,
Got a lowish mileage used transfer case in the mail yesterday. Replacing mine due to failure... Just wanted to know if there is some preventative maintenance that I can do before it gets installed since it's just sitting there waiting to go in. Thanks!
Old Apr 14, 2012 | 12:28 PM
What year is the replacement t/case from, needs to be an 03 or 04.
Old Apr 14, 2012 | 12:34 PM
Hey Mike, it is an 03 t-case. 60k miles on it.
Old Apr 14, 2012 | 12:40 PM
During shipping any metal chunks may have migrated to who knows where. Flush with solvent of choice and rotate by hand? While watching thru inspection plate opening? Reseal inspection plate (famous for leaking)? We already suspect that high quality lube will be installed. Any O ring on the neutral safety switch to swap out? And any other O ring or easy to change small gasket. Lube shifter like you never plan to be back in there. If CDL or CDL conversion lube other parts. If no CDL respect the fact that you won't be able to do everything off road that some Rovers can. And clean out the vent line and banjo bolt for the breather pipe that allows fumes to escape.
Old Apr 14, 2012 | 12:42 PM
Sounds good, just wanted to make sure.
Consider replacing the front seal on the t/case and the tail shaft seal on the tranny.
Make sure to use a good 75 or 85/140 gear oil for better wear protection.
Old Apr 14, 2012 | 12:57 PM
By the way, have you already rebuilt your front drive shaft, if not, this is a good time along with replacing the rear u-joint.
Old Apr 14, 2012 | 02:58 PM
Dually noted fellas, thanks once again for your expertise. I will certainly take your advice. Rear shaft has already been built. Will follow up with results or any issues I experience.
Old Apr 14, 2012 | 05:05 PM
I agree, replace the seals.
bcolins
Mar 8, 2015 04:07 PM
pwaltrip
Jun 4, 2012 02:06 PM
bcolins
Jun 15, 2011 01:29 PM
Garrett
Dec 8, 2010 07:08 PM
gsxrgessler
Feb 15, 2010 09:48 PM
