Transfer case replacement
Old Jul 17, 2008 | 12:26 PM
okdiscoguy's Avatar
Default RE: Transfer case replacement
Might be one of your diffs also. I think you have a rotoflex on the rear shaft, so it probably wouldn't transfer up that shaft, but it might from the front shaft.
Mine sings a little under acceleration, but hasn't gotten any worse in 3 years.
Old Jul 17, 2008 | 05:47 PM
ORIGINAL: melmanc55
They are going to do a flush and change out the fluid (it's at the dealer right now) before we go down that road. You know the car is not vibrating or making a grinding noise. Just a humming under accelaration. We'll see.
Have them change the fluids in the differentials and transmission too. Then just drive it. When your t-case does finally go out it will start to sing so loud you cant talk to your passenger.
Change all the fluids, drive it and forget it, I bet it last's another 95k.
Just change all your driveline fluids every 50,000 miles and you'll be good to go.
Rovertroubles
Jun 3, 2015 04:45 PM
jegomes
Oct 23, 2011 02:50 PM
jasonmoore
Aug 8, 2011 07:02 PM
Loose_Screws
Jul 22, 2005 12:13 AM
Smokeyone
Jun 4, 2005 03:11 AM
