Transfer Case replacement
Old Oct 21, 2011 | 10:48 PM
jegomes's Avatar
Awesome info guys... I love that you can get help here and not just get flamed.. much more civil then other forums.. and another question if I may anyone know the weight of the lt230 with the parking break drum on? basically I'm asking if two healthy guys can do a swap with out the use of a jack.
Old Oct 22, 2011 | 08:03 AM
antichrist's Avatar
Yeah, you should be able to.
Get some long 10mm x about 180mm bolts and cut the heads off, round the cut ends and fit them to the transmission to use as guide pins. You have to feed the high/low selector rod in to the yoke while fitting the transfer case so you may need 5 hands if you don't use guide pins.
Old Oct 22, 2011 | 10:03 AM
Save yourself a lot of money and consider buying a good 04 t/case and have it installed.
Old Oct 23, 2011 | 07:44 AM
antichrist's Avatar
Exactly how is paying someone else to install it going to save him "a lot of money"?
Old Oct 23, 2011 | 08:10 AM
jegomes's Avatar
what does the 04 offer.. I was under the belief that 99 thru 01 was a direct replacement.. is the 04 a better choice
Old Oct 23, 2011 | 02:50 PM
antichrist's Avatar
Also, don't assume the CDL light switch works. Test it and adjust it before you install the transfer case. Trust me, it's a lot easier out of the vehicle.
Rovertroubles
Jun 3, 2015 04:45 PM
jasonmoore
Aug 8, 2011 07:02 PM
melmanc55
Jul 17, 2008 05:47 PM
Loose_Screws
Jul 22, 2005 12:13 AM
Smokeyone
Jun 4, 2005 03:11 AM
