Transfer case solenoid
Old Aug 24, 2007 | 11:55 AM
stanigu's Avatar
Default Transfer case solenoid
My transfer case is stuck on Hi, and I cannot shift to Lo. It's been traced to the solenoid that locks the shifter which is stuck for some reason.
I checked the fuse, and it's fine, so probably not electrical problem....I'm thinking that I want to just remove the pin from the solenoid. I don't think I'll be stoopid enough to try to shift while the gear's engaged...
I've heard that you can get to this solenoid from the center console, without having to drop the transfer case. Has anyone done this?
How do you pull the **** off both the transfer case and the gear selector poles? It's on there pretty tight...maybe just yank?
If anyone's done this, I'd really appreciate your input! Planning on spending all day tomorrow tackling this project...
Old Aug 24, 2007 | 12:07 PM
Default RE: Transfer case solenoid
You can remove or disable the solenoid, it is only there as a saftey device, I have done this before but know that it can be done, going thru the console with out pukking the t/case.
Old Aug 29, 2007 | 04:48 PM
stanigu's Avatar
Well, I got stuck at one of the first steps: Taking off the **** for the gear shifter (PRND thing). I understand it's just pressed on, but man, it is on there tight. If anyone's sucessfully pulled one off, I'd like to know how you did it!
Old Aug 29, 2007 | 05:00 PM
dow's Avatar
dow
you have to pry off the top cover first, then theres a pin in there with a little locking clip on it, remove that and you can get the button out and access the 13mm nut that holds the whole thing on, be sure you dont lose the spring for the button, once you remove that you can get the gear shift off
as for the transfer ****, its screwed on, just turn it
Old Aug 29, 2007 | 05:41 PM
stanigu's Avatar
I don't see a cover on the shifter...must be difference bet. DI & DII.
Old Aug 29, 2007 | 05:47 PM
dow's Avatar
dow
oops, forgot to look at your signature, haha
yea, its probably a difference there
Old Aug 29, 2007 | 05:57 PM
dow's Avatar
dow
looked at a few picts online and it seems that the transfer **** and the shifter may just be screwed on, not pressed on, not entirely sure of that though, try giving it a turn
Old Aug 29, 2007 | 09:12 PM
johnkbl's Avatar
You can download a copy of the rave cd here:
http://green-oval.com/joomla/index.p...&Itemid=29
The relay that activates the solenoid is under the glove box.... After downloading your rave cd, you can mount the iso file using Alcohol or a similar program.
That cd has all the information about the wiring and component location of your car. Maybe instead of removing your solenoid, you can find the problem and fix it...
Hope it helps...
Old Aug 30, 2007 | 11:43 AM
stanigu's Avatar
Thanks for the link. Great resource.
I believe, though, that the solenoid defaults to "locked" position w/o power, so it has to be a mechanical fix.
Jupe209
Feb 4, 2026 06:19 PM
moncton_vw
Sep 16, 2011 05:55 PM
twaszak
Jun 27, 2011 01:32 PM
jutgin
Sep 28, 2007 10:54 PM
