Transfer case stuck in high
Old Dec 14, 2017 | 11:41 AM
Fastercat's Avatar
I believe my solenoid is not working as I have disassembled and lubed my cable, installed a new CDL linkage and still can’t get low range to engage. Is the solenoid easily accessible from the top through the transmission tunnel plate? Any idea how much a new solenoid would cost? I looked on lucky8 but didn’t see one listed.
Old Dec 14, 2017 | 03:58 PM
Motorhead1's Avatar
You can remove the solenoid from inside. It's a pain, but doable. Most of us just remove the solenoid and call it a day....
Old Dec 15, 2017 | 11:50 PM
number9's Avatar
Originally Posted by Motorhead1
If your transfer case is stuck in high range, you have a bad transfer box hi/low shift solenoid.
Mine was unable to shift into low. After changing the XYZ switch due to S&M/limp it was no longer locked out of going into low.
Not necessarily recommending a XYZ would be a fix but may be worth checking the solenoids control circuit.
Old Dec 16, 2017 | 09:07 PM
T-rex's Avatar
I've got a sticky solenoid on mine - the hotter the engine the less likely it will shift into low. Cold engine it will shift almost every time.
Old Dec 18, 2017 | 04:03 PM
Motorhead1's Avatar
Yes, Classic example of a failing solenoid. Mine did the same. Wasn't long before cold shift wouldn't work either...
Old Apr 17, 2018 | 10:25 AM
Explorer0863's Avatar
If it works without the solenoid, what is the purpose of it? I am having the same problem and considering getting rid of it. Thanks.
Old Apr 17, 2018 | 04:05 PM
Best4x4's Avatar
Keeps it from being bumped into N or god forbid 4lo at 80MPH while in gear...
Old Apr 18, 2018 | 09:19 AM
Motorhead1's Avatar
It's a safety feature that basically all cars have now also. So a person can't knock the vehicle into neutral with the engine off. The transfer case over rides the transmission.
Old Apr 18, 2018 | 09:34 AM
Best4x4's Avatar
Most other 4wd’s that don’t use an interlock solenoid have a shift pattern. On the LR it’s just straight up and down & without the solenoid to hold it into place it would be very easy to bump or just pop out of gear.
I prefer the setup on the 03 Linkage/04 CDL linkage where the solenoid is externally mounted vs 94-02 where it’s actually mounted on the TC.
Old Apr 18, 2018 | 11:21 AM
Motorhead1's Avatar
Who are we kidding?? Almost all vehicles built today are electronically switched into four wheel on the dash?? lol
