Transmission Fluid
Old Aug 1, 2005 | 03:38 PM
ferrelltodd's Avatar
Default Transmission Fluid
I have a 2001 Discovery. Stupid question, but where the heck is the Transmission Fluid Dipstick? Looked all over the engine compartment and didnt see it.
Old Aug 1, 2005 | 05:02 PM
duboff's Avatar
Default RE: Transmission Fluid
passenger side of the engine compartment back by the fire wall. welcome to the forum, no such thing as a dumb question. if you have one the exact location is in the owners manual in the maintainencce section. if I can help in any way, let me(us) know. hope it helps, gotta love a rover. duboff
Old Aug 2, 2005 | 12:02 AM
Bait's Avatar
There is no dipstick. Fluid level is checked via a plug on the pan.
Old Aug 2, 2005 | 12:18 AM
jasonsLR's Avatar
i was having the same problem last weekend
i don't have a manual to look these things up on my 02'
i my not shure of what you mean by a plug,
will the plug not drain the fluid.
thanks
Old Aug 2, 2005 | 12:30 AM
Bait's Avatar
The procedure is, Start engine cold, put in neutral, remove plug 8 mm allen from the front of the trans pan whilst running. Fluid should just drip out. The drain plug is on the bottom of the pan, 6 mm.
Old Aug 2, 2005 | 11:20 AM
What a pain. I was going to add some transmission treatment. How can I get it into the pan?
Old Aug 3, 2005 | 01:23 AM
Bait's Avatar
Ahh... I think this was one of the reasons for deletion of the dipstick. No "treatments" are needed.
Old Aug 3, 2005 | 05:40 PM
How often should I change to transmission filter?
Old Aug 4, 2005 | 01:21 AM
Bait's Avatar
Filter replacement is only needed once @30K. If you tow, change the fluid every 30K.
Old Aug 9, 2005 | 10:11 PM
for regular use, how often do I change the fluid?
Athana
Jun 8, 2019 10:23 AM
Rolltop
May 5, 2014 09:17 AM
1998DiscoverySE
Jul 20, 2012 08:02 PM
LRScott
Mar 4, 2009 08:39 AM
jmang
Oct 17, 2006 06:58 PM
