transmission fluid question
Old Jan 20, 2019 | 03:57 PM
Richard Gallant's Avatar
Default transmission fluid question
Ok , so my filler plug was messed up a bit and I went to replace it. Got my Disco level went underneath and after some hard work managed to get the old one loose, so far so good.
When I went to take the old plug out I got a stream of fluid out not a trickle, the loss was relatively minor as I had the new plug beside me so a fast change over, maybe a quarter of liter at the most lost. My concern of course is was my transmission over filled or was my disco simply not level enough.
The fluid was nice bright red, so no signs of contamination.
The flow was stopped by the new plug not drainage
Old Jan 20, 2019 | 04:09 PM
Friday Night Disco's Avatar
Too much fluid can cause problems. Was the truck running when you checked?
Old Jan 20, 2019 | 04:14 PM
Nope cold and off, which as I understand it is correct
Old Jan 20, 2019 | 04:15 PM
Originally Posted by Richard Gallant
Nope cold and off
I would check the level again with the engine running and in neutral, I believe that is how you are suppose to check the level. You should have a small steady stream coming out, if that is the case you are good.
Old Jan 20, 2019 | 05:01 PM
shanechevelle's Avatar
Running. And buy a disco 1 pan. It comes with a dipstick and bolts right up.
Old Jan 20, 2019 | 06:31 PM
mollusc's Avatar
d2 transmission is supposed to be filled with the engine running. with the engine off the fluid level inside the case is quite a bit higher, so it flows out quite quickly.
Old Jan 20, 2019 | 08:10 PM
Thanks to all who responded, I re-read the notes and RAVE so that was an oops on my part. But easy to rectify at least.
Old Jan 26, 2019 | 05:07 PM
Bulax99's Avatar
To shanechevelle. I didn’t know you could bolt up a DI pan. Is this a retro kit that someone sells?
Old Jan 26, 2019 | 06:00 PM
Extinct's Avatar
no kit, just get one from one of the forum parts sellers, get the dipstick too.
Prattvilledisco
Sep 29, 2016 12:35 AM
Externet
Sep 20, 2014 07:23 PM
chicane
Apr 11, 2014 08:04 AM
seminolef1
Nov 9, 2012 09:58 AM
dalfier
Jun 21, 2007 01:45 AM
