Transmission Fluid Temperature Warning Light
Old Sep 19, 2017 | 05:12 PM
Four Engines and Counting's Avatar
Default Transmission Fluid Temperature Warning Light
Came up as a result (I expect) of driving the Disco around in the Harvey floods.
How easy to change the ATF and will this do away with the warning light?
How far can I risk driving before I change the ATF?
Thanks
Old Sep 19, 2017 | 06:13 PM
Friday Night Disco's Avatar
Thanks
easy to change tranny oil, you can get a kit from lucky8 or AB. If you have a code reader post the code. You will need some metric Allen wrenches and a hand pump for the oil.
i wouldn't risk driving the truck till you know what code is causing the light to come on.
Old Sep 19, 2017 | 06:21 PM
Kdo58's Avatar
Old Sep 19, 2017 | 06:22 PM
Red5's Avatar
If it is the high temp light you're talking about, so long as you did not get water in the trans, let it cool off and you should be fine. As you said, the light is probably from of pushing all that water out of your way. The extra stress on the trans heats the fluid more than normal.
Under the same conditions, new fluid would probably trigger the light as fast as old stuff, but you should change it anyhow if you have not done it in a while. It is an easy driveway job. Change the filter too, it's not expensive and takes a few extra minutes.
https://landroverforums.com/forum/di...uid-dii-23070/
Old Sep 19, 2017 | 08:12 PM
abran's Avatar
T case can trigger the light as well.
Old Sep 19, 2017 | 08:33 PM
I would check tcase fluid levels if it gets low it will trigger this.
Old Sep 19, 2017 | 08:50 PM
Bom2oo2's Avatar
Since you drove in very deep waters (as you mentioned), it's best to check all fluids, trans / both diffs/ T-case, to make sure you don't have water in them,
Old Sep 19, 2017 | 09:23 PM
Red5's Avatar
How? Is this the light we are talking about?
Old Sep 20, 2017 | 12:00 AM
abran's Avatar
Check the RAVE manual.
Old Sep 20, 2017 | 09:58 AM
It's the little red light at the top right of the instrument cluster that looks like a thermometer in a puddle.
My pal at JLR told me to change the transfer case oil and diff oil, so I'll do the transmission while I'm at it.
ATF sure is expensive. How many liters / quarts do I need?
Can I use regular ATF for the tranny and / or regular EP90 for the diff and transfer case or does it have to be special stuff made from unicorn pee or something stupid?
I have to drive about 60 miles in it today as I need a car with a roof rack to carry a ladder, but it's all freeway, so I should be okay, I hope, for that. I can pencil in the changes for next week, do the engine oil, tranny, diff and transfer case all in one day.
Another question - how easy is it to fit high level tranny etc. breather kits to stop water getting in next time we flood?
