Transmission Issues / Questions
Old Dec 7, 2021 | 08:45 AM
adalton's Avatar
Default Transmission Issues / Questions
Hi all,
My transmission has been fantastic other than a strange lurch from 1st to 2nd gear when accelerating from a stop. Only happens when accelerating slowly. Ive heard that at high mileage you shouldn't change your transmission fluid on these trucks? I have 125k and I have no knowledge of the transmission fluid being changed. I am capable of changing it myself and know the process on these trucks.
Old Dec 7, 2021 | 10:01 AM
redwhitekat's Avatar
i would change it and maybe put a additive in it, there is also a filter in there, I've changed 2 or 3 tranny fluids over the years and never had a issue, just follow the procedures on how to fill it and check the level while its running,
Old Dec 7, 2021 | 10:13 AM
whowa004's Avatar
get a d1 transmission pan to swap in when you drain it. D1s and Classics came with dipsticks which make checking level and even topping off much simpler.
Old Dec 7, 2021 | 02:15 PM
Harvlr's Avatar
Does the pan just swap straight in? I have one from a GEMS P38 which should be the same.
Old Dec 7, 2021 | 03:09 PM
whowa004's Avatar
yep, fresh gasket and should be good to go.
Old Dec 7, 2021 | 05:23 PM
Harvlr's Avatar
Cool! Next oil/filter change.
Old Dec 7, 2021 | 07:11 PM
adalton's Avatar
Sweet! Thanks guys. Going to order new pan and do my oil and filter change soon.
icatterm
May 31, 2024 07:08 PM
flybd5
LR2
May 19, 2021 11:23 AM
Steve Berlage
Oct 24, 2019 06:43 PM
luckyd77
Jul 2, 2017 09:06 PM
treant985
Dec 27, 2010 02:51 PM
