Transmission Mode switch
Mine does not seem to be functioning, I have not checked low range/manual but Hi/Sport does not illuminate the light.
It did work prior to doing my head gaskets
- Lights do work when the key is 1st turned on as per all the other lights
- Charging via torque show between 13.6 and 14.1
- Everything else appears to work correctly
Richard Gallant (03-10-2020)
Sixpack577 (03-10-2020)
@mollusc Funny thing about that I also put a "new" alternator in, I was going to check it out as my VHF radio reset when I was trying to send, that is always power or ground.
Then it occured to me that ground had been removed, I wrote a big note to check this am and the nut was barely hand tight
