Transmission Mounts need a little help
OK so I'm doing the Transmission filter and fluid change on my 03 Disco I just bought. I got it for 6500 because it was rear ended, It has just over 100,000 miles on it. So I noticed that the trans mounts look damaged and it appears that the transfer case is moved to the front about an inch. On the pictures the front drive shaft is tight and the rear drive shaft has space. The crossmember has broken five of the eight bolts. So my fix is just to remove the bolts, remove the old mounts, and using a floor jack move the Transfer case back so that it is even and use new mounts to attach it back to frame. Is there something I am missing or should that cover it? I'm worried that there could be more to it.
Yeah I checked the motor mounts and they seemed fine I wanted to make sure though when looking for the transfercase mounts it only came up with Transmission mounts at british atlantic. The mounts that are damaged are definitly attached to the Transfer case not the transmission. Am I ordering the right thing when I order the right and left transmission mount? Also I have replaced all three ujoints on the front drive shaft. I'm trying to get through the major service one step at a time before I look at lockers, lift rims tires, armor and so on. There is much money to be spent this truck is just for when I go mountain biking, camping, and off roading. Thanks for the help
ArmyRover
01-29-2015 11:26 AM
LPs HSE
06-19-2007 09:12 PM
