transmission oil
Old Sep 17, 2008 | 12:34 AM
theworks001's Avatar
Default transmission oil
Any brand in particular?? that you guys use for your tranny?? thanks
Old Sep 17, 2008 | 01:29 AM
Jupiter Rover's Avatar
Default RE: transmission oil
Royal Purple is great stuff.
Old Sep 17, 2008 | 02:17 AM
Disco2Guy's Avatar
I have a box of Mobil1 Syn ATF ready to go in.
Old Sep 17, 2008 | 08:09 AM
Castrol ATF.
Old Sep 17, 2008 | 02:11 PM
Switzer's Avatar
Valvoline dexron/mercon Maxlife.
Cheers,
Pete
Old Sep 18, 2008 | 12:19 AM
sdsilvere38's Avatar
I have a 96 disco in a 5 speed. How much fluid should I use? Is there a filter to change as well? What are the proper steps....
Old Sep 18, 2008 | 12:53 AM
IDAHODISCO's Avatar
Old Sep 18, 2008 | 11:48 AM
It is a waste of money to add some synthetic to old ATF. The only way that can be done right is a total flushj of the system and if you mileage is too high, it can cause the tranny to fail.
What year, model and mileage??
Old Sep 18, 2008 | 11:58 AM
Is it safe to drain mine and refill? 96 disco in a 5 speed with 115,000.
Old Sep 18, 2008 | 12:09 PM
I am not sure about a manual trans. I do not know the drain/fill procedure or what type of fluid it takes. Sorry I cant help you on this one.
