Transmission P0705 Wiring help
Old May 15, 2026 | 05:16 PM
connocclar's Avatar
Default Transmission P0705 Wiring help
Looking for some help on fixing a p0705 code I have with flashing M+S. Ive found these 2 connectors unplugged on top of my transmission and need help finding where they go. They are located up stream from my XYZ switch plug. Thanks.
Old May 15, 2026 | 05:49 PM
Extinct's Avatar
Look like transfer case position switch connectors. Have you looked in the RAVE for wire colors and plug photos.
Old May 16, 2026 | 02:31 PM
connocclar's Avatar
It's 2 single black wire plugs, so I think* they are grounds, from looking in the RAVE, they are both same diameter. Im just terrible at reading the wiring diagrams. I also have no idea where I would plug them in, I took my boroscope and looked on top of the transfer case and everything appears plugged in.
Old May 16, 2026 | 03:43 PM
connocclar's Avatar
I found this bent on top of the transfer case, looks like maybe something should be attaching here?
Old May 16, 2026 | 06:07 PM
connocclar's Avatar
Went ahead and removed my shift selector and took the plate off just to triple check and everything appears to be plugged in. Realized 1 wire is black with a super dirty green stripe which I think is the reverse light. Still no idea where I could hook up the ground. Think cutting it and putting a ring terminal on it would work?
Old May 16, 2026 | 08:19 PM
connocclar's Avatar
After going through plug photos again, It seems both of these plugs are for the transmission oil temperature switch, which I do not have equipped. This wouldnt just now be causing the flashing M&S light right?
Old May 16, 2026 | 08:21 PM
connocclar's Avatar
Old May 17, 2026 | 05:01 AM
Extinct's Avatar
That would not cause flashing M&S, but it would be unusual for you not to have the sensor. What is in the place of the sensor on your tcase?
Old May 17, 2026 | 09:06 AM
connocclar's Avatar
It's plugged with a bolt it appears.
Old May 17, 2026 | 02:36 PM
connocclar's Avatar
Looks like just a plug
