Transmission problems....
Old Aug 7, 2012 | 04:44 PM
kman35ca's Avatar
Default Transmission problems....
K driving to work today on the highway. As from a before mentioned post. My transfer case in neutral light was flashing with an audible warning. Fixed that by just cleaning up all the connectors going to T Case. But when that started it also started shifting late and hard into 2nd gear and also just eating up the gas. Gonna drain the tranny and see what i find and check the diffs. What do you guys think? I'm hoping its not a new tranny for me, which seems very possible.... Any similar experiences and or input would be much appreciated. Thanks
Old Aug 7, 2012 | 05:03 PM
Gosh, you can do the tranny filter so much easier than a D1, may want to do that as well. There is also a switch on the left side of tranny (the XYZ switch) that can get full of gunk, and need to be replaced or opened up and cleaned out and re-sealed. Trannys throw codes as well.
Old Aug 7, 2012 | 06:03 PM
kman35ca's Avatar
Ya I'll check that out. One thing, It didn't throw any codes so hopefully it's something minor.
Old Aug 7, 2012 | 06:35 PM
lr2001silver's Avatar
Banned
The transmission is the strongest part on these trucks unless of course it takes a blow from the drive shaft. They usually don't just fail if they are properly maintained. Like buzz said i would do a filter and fluid change and also check all connections including xyz check solenoids and electrical parts first before tearing apart the trans.
los
Jun 1, 2009 10:43 PM
toyotacrazy8180
Feb 26, 2008 11:20 PM
chris@wdainc.org
Oct 18, 2007 06:49 PM
dirtdude
Freelander
Jun 28, 2007 09:41 AM
cold_surfer
Mar 19, 2007 01:13 AM
