transmission question
Old Feb 26, 2009 | 07:44 AM
discoxd's Avatar
Default transmission question
will the auto trans out of a 95 with the 3.9 bolt up to the 4.0 in a 97 D1? im just asking because my 97 has the sprag clutch issue where i have to manually shift my auto trans, but the 95 i scooped up the other day shifts just fine... so i am thinking about swapping them out since the 95 will soon be a trail only rig... and has anyone pulled their transmission out? how difficult a job is this? i know its not like changing plug wires and is a pretty involved procedure but is it all relatively straightforward?
Old Feb 26, 2009 | 09:26 AM
jycsalas's Avatar
According to RAVE... Discovery models 95 through 2002 use transmission ZF4 HP22. The 2003 -2004 Discovery use the ZF4 HP24 which is 15mm longer to accommodate a larger fluid pump. (Unless i mis-read something)
I would say yes it should just bolt up. I simply don't know anything about how compatible the shift cable, switches, etc, might be. Hopefully someone will give their two cents.
Old Feb 26, 2009 | 09:46 AM
AK Rover's Avatar
Yes your transmission from the 95 will fit the 97. The 3.9 and 4.0 are the same engine with the exception of the 3.9 uses a distributor.
Old Feb 26, 2009 | 09:48 AM
discoxd's Avatar
sweet
Old Feb 26, 2009 | 10:07 AM
Don't get to happy to soon, http://www.roverlandparts.com/transm...-complete.aspx
shows the 95 tranny as different from a 96 thru 99 D1.
I would ask someone that is into trannys and get the correct information.
Let us know
Old Feb 26, 2009 | 10:25 AM
discoxd's Avatar
crap.
Old Feb 26, 2009 | 07:51 PM
roverguy7's Avatar
itll fit. you will most likely have to change the rear housing, it just bolts on and off, its what mates up the to t-box. but the tranny itself is the same
Old Feb 26, 2009 | 08:32 PM
discoxd's Avatar
i guess i am just gonna have to unbolt the both of them and see for myself... if i ever get around to it i will be sure to post up what i find out.. thanks guys...
hubris
Dec 14, 2007 09:31 PM
open range
Mar 21, 2007 02:00 AM
Benhamtroll
Feb 9, 2007 11:17 PM
stripperluvva s wife
Mar 24, 2006 11:49 AM
JKK
Oct 13, 2005 10:49 PM
