transmission quit
Old Nov 12, 2012 | 10:17 AM
ttwndoc's Avatar
I drained the tranny fluid. It didn't look burned or have a bad odor. wasn't red color just a light tan color. I plan to drop the pan and change filter and put new fluid in it. Anybody have any other thoughts or suggestions on how to fix this. I really don't want to change the transmission. but if I have too I will. Thanks
Old Nov 12, 2012 | 10:20 AM
Do a drain and refill adding one bottle of Lucas tranny additive and see what happens.
Old Nov 12, 2012 | 10:27 AM
ttwndoc's Avatar
Okay thanks for all the help. I found a wire loose. I think that is what threw the sensor code. It hasn't reappeared yet. Is it possible to clog a tranny filter and it have this effect on the tranny?
Old Nov 12, 2012 | 10:37 AM
Only if the tranny a blown up by a hard part, other wise, normal wear and tear will not plug a D2 filter. If it were plugged that bad, I wouldn't even waste doing a flush, it is a goner.
Old Nov 12, 2012 | 10:57 AM
ttwndoc's Avatar
Tonight I will drop the pan and check inside. Hopefully is just needs a flush. Do you think its a goner Mike?
mbonthenet
May 23, 2009 09:33 AM
Chrisinhouston
Feb 25, 2009 06:15 PM
saltydog86
Jan 11, 2009 07:33 PM
dinandan
Mar 20, 2008 08:22 AM
discodan
May 9, 2006 01:32 PM
