Transmission, service
Old Apr 6, 2010 | 02:19 PM
Carl082974's Avatar
Default Transmission, service
For a 2001, Disco II, 157k miles
Does anyone know how often the transmission need to be serviced?
Or just how often the transmission oil should be changed?
A mechanic that specializes in Land Rovers told me that the Disco II does not need to have this done.
C
Old Apr 6, 2010 | 02:54 PM
yloDiscoII's Avatar
He did huh? Hmmm....I am NOT a mechanic, but never servicing your tranny doesn't seem very logical to me. Transmission fluid will break down/get dirty over time just like other the other fluids in your vehicle. At your mileage you shouldn't do any sort of chemical flush, but drain and fill with a new filter is a must IMO.
The most common number I've heard for a change is every 30K. Auto Zone sells a filter/gasket kit for $14.99, AB has them for around $50 I think.
Old Apr 6, 2010 | 03:22 PM
At your mileage, every 20,000 miles cause she is no spring chick any longer, using a filter and some Lucas tranny additive every other change.
Old Apr 6, 2010 | 05:01 PM
Land Rover says to change the filter at the first 30k and then leave it alone on DII's.
Personally I change my filter once every 50k and the fluid once a year no matter the miles.
For you I would change the filter and fluid because you have no idea what or when or if anything has ever been done to your truck.
Old Apr 6, 2010 | 05:26 PM
tweakrover's Avatar
I'll ask here so I don't have to open another thread, but how do you catch 12 quarts of fluid under the truck? does some stay in the torque converter when you drain it ?
Old Apr 6, 2010 | 05:48 PM
herblatham's Avatar
ya, you won't get the full 12 quarts of fluid out, i don't know how much, but some does stay in the torque converter.
Old Apr 6, 2010 | 05:49 PM
If you do a drain and fill you will only loose ~5 qts from a DI.
If you change the filter you will loose ~10 qts.
As long as you change the fluid often it is not as important to get all of it out.
Old Apr 6, 2010 | 06:23 PM
greenwade's Avatar
The easiest way to catch all of the fluid that drains out of the tranni, or any fluid for that matter, i have found is to do it over a sewer grate.... helps the fish swim through that water easier.
But really, i have found that the "oil changing pans" that you can buy are too small and worthless. Head down to wallmart and grab a large, shallow, plastic bin. It is what i use and cost like 5 bucks.
Old Apr 6, 2010 | 06:25 PM
tweakrover's Avatar
cool that helps alot. I just was thinking 12 qts in one drain pan was going to be a big mess.
Old Apr 6, 2010 | 06:33 PM
Rovin4life's Avatar
just pay for a bg transmission flush. its easier and it changes all the fluid the first time.
