Transmission Sump Problems
Old Nov 7, 2010 | 08:15 AM
Fireman's Avatar
Default Transmission Sump Problems
Well, I decided to change my tranny fluid and filter yesterday. Everything was going as planned, until I got to the last bolt. The sixth bolt had 'cold welded' itself into the aluminum clamp. Before I knew it the head had sheared off the bolt! After much cursing I managed to get the pan off and, finally, the clamp off the remnants of the bolt (clamp broke in process - more cursing).
So, now I have the remnants of the stud to deal with (too close to the tranny internals to use a stud extractor or a torch). Only option, with regard to the stud, might be to tack weld a nut onto the end and try and back it out, but I am open to other ideas...
My other problem is I need to find a replacement clamp - any ideas?
I currently have the pan back on and I am using a very small c-clamp to hold that corner of the pan in place....
Old Nov 7, 2010 | 08:36 AM
I got nutin' but I will give you a bump.
Old Nov 7, 2010 | 08:41 AM
DarylJ's Avatar
Do you mean you have the remnants of a bolt to deal with?
How much of it is sticking out? Don't discount a pair of vice grips - if it was just bound at the bolt head, it may come out easily. Next up, if you don't have the space would be tacking a nut to it, like you suggested. If you don't have enough space to do that, carefully drilling and using a spiral flute extractor (ez-out) would probably be next.
But it's tough to give you suggestions without pictures of just what you got yourself into.
Dealer only unless you can find a used one from a small tranny shop.
Old Nov 7, 2010 | 08:47 AM
frankieoboy's Avatar
You could try having another bolt welded to the end of the stuck one
Old Nov 7, 2010 | 09:20 AM
Fireman's Avatar
Damn, I guessed it would be dealer only, but I hate those blood suckers!
Yeah it is the remnant of the bolt. It is long enough (~1") but only ~3/16" thick, so the vice grips aren't really gripping it. I can only get them in inline with the bolt as there isn't enough room to get them on perpendicular to the bolt. If I could get them on perpendicular to the bolt I'm sure I could get it out.
I'm thinking I may be forced to cut this one off and drill and tap a new hole.
I'll see if I can snap a couple of pictures...
Old Nov 7, 2010 | 10:15 AM
Fireman's Avatar
As promised...
A picture says a thousand words...
Old Nov 7, 2010 | 10:33 AM
lordmorpheus's Avatar
If the threads on the bolt (now stud) are clean enough, could you possibly double nut it? Unless you have ready access to a welder to tack weld a nut on the end, this is the approach I would try, after soaking down the end where it goes into the transmission with PB Blaster. If space is too limited to tighten the two nuts together, possibly dremel a slot in the end of the bolt for a screwdriver (again after soaking down the opposite end with PB Blaster)
Old Nov 7, 2010 | 10:41 AM
Fireman's Avatar
I think I may have found just the tool to pull the remnants of that bolt...
This has a 1/2" drive so once tight I could get the impact driver on it.
Old Nov 7, 2010 | 01:29 PM
DarylJ's Avatar
As promised...
Oh....so by "I don't have enough room" you actually mean "unless I take the pan back off."
Yeah...you can try some other things, but I find that bolt extraction is nothing to play around with. I always prefer to get the best angle with the most surface contact I can on things as to avoid larger problems when quick first attempts fail.
Wish you the best, but I'd sugest doing it the long but correct way.
