transmission swap question
Old Jun 6, 2013 | 06:21 PM
Jason428sc's Avatar
Default transmission swap question
Hi guys,
Can anyone tell me if a 2001 Discovery transmission will fit a 2003 Discovery? I've got a chance to by a 2003 with a bad transmission and have found a 2001 transmission. Any help would be appreciated. Thanks.
Old Jun 6, 2013 | 07:09 PM
Disco_Fever's Avatar
Yes, the trans is the same. Have fun with the swap... How much is the trans? I think Will Tillery sells them for only $500 and offers a good warranty.
Old Jun 6, 2013 | 07:49 PM
Jason428sc's Avatar
Thanks Bryce, the tranny I found is $300 without a warranty.
Old Jun 6, 2013 | 09:39 PM
ZGPhoto's Avatar
They're not the same.
Old Jun 6, 2013 | 10:16 PM
jafir's Avatar
True story. The 03-04 have a heavier duty version for the larger engine.
Old Jun 6, 2013 | 10:21 PM
ZGPhoto's Avatar
I would have mentioned the two part numbers but I can't remember them, it's like 4bh22 or something. I'll try to find it. The later one is a half inch longer.
Edit: The early(99-02) is 4HP22 and the later(03-04 to handle the 4.6L) is 4HP24 both ZF transmissions designed in the 80s...
Old Jun 6, 2013 | 10:26 PM
Jason428sc's Avatar
thanks guys for the info. I'll see if I can find one from an 03 or 04.
Old Jun 6, 2013 | 10:41 PM
Fivespddisco's Avatar
It will work
BUT
Get everything from the flywheel back. The spacer rings are different and if you put the 03/04 in it may burn itself up
Old Jun 7, 2013 | 05:39 AM
drowssap's Avatar
and you would need the drive shaft also as they are different lengths
Old Jun 7, 2013 | 08:53 AM
Well, don't I feel stupid. That's what I get for assuming anything!
BUT, on a more positive note, I am parting an '04 D2 w/ 82k miles on it. Ran and drove fine before I started pulling bits from it, I personally put about 100 miles on the truck before starting the part-out. I had the trans tentatively sold to a friend for his '01, but now realize it won't be plug & play for him. BUT, it would be for you! I'd take $400 for the trans, but we have to figure out shipping.
