transmission temp light on/off
Old Apr 8, 2012 | 11:40 AM
marizcal's Avatar
hi to all... here is an update...
check the fan clutch....bad conditions... turns a while with the engine cold...... changed
in process to change the trans filter and oil....
check the transfer case oil... good conditions, clean oil and good level....
return later with comments about the problem...
thanks a lot for comments and advices....
Old Apr 8, 2012 | 09:52 PM
marizcal's Avatar
ok... bad news...
I finish the trany filter and oil change... and take it for a 10 min trip... and the light goes on again....
next step... clean the radiator panels.. coolant and oil ones....and see if it corrects something...
by the way..any one knows the value of the oil temp sensor? in ohms, when is cold....or any way to check it.. with ohmeter or voltimeter?
thanks...
Old Apr 9, 2012 | 04:45 AM
See pix of tranny switch - unplug - repeat test drive - if light comes on it is the transfer case temp sensor. Either tranny or transfer case can make a over heat oil light come on. Both are a switch, so either a short or an open on the ohm meter or test light. You have checked transfer case oil for filled up?
File Type: pdf
Old Apr 9, 2012 | 08:50 PM
marizcal's Avatar
Hi, again... just for comment that I already unplug the front sensor when the light is on, and the light goes off... so this is the one that is sending the order...and for the transfer case oil...I check it and it is to top... it is clean in good shape... no need to change it...I think so...
What else I can check????
thanks a lot for your advices and comments... pending...
Old Apr 9, 2012 | 08:56 PM
It is common for the trans temp sensor to go bad on DII's.
Old Apr 9, 2012 | 09:42 PM
marizcal's Avatar
Bad sensor... it could be..but someone knows the part number?
Old Apr 11, 2012 | 01:52 PM
burdickmd's Avatar
4wd High
Atlantic British lists it:
Sender Oil Cooler Temperature Transmission (Genuine Part # UBI100030) - Land Rover switches/control unit/actuators from Atlantic British
Hope that fixes it!
Old Apr 14, 2012 | 03:28 PM
marizcal's Avatar
Hey, back again... I reading and searching.. and found this other thread in this same forum..
https://landroverforums.com/forum/di...e-light-33728/
about the trans temp gauge on... going to make a visual inspection of the sensor and of course clean the radiator panels... or try to do it...because it is difficult to reach all of them.. posting later..
thanks to all...
thanks burdickmd for the part number...
Old May 4, 2012 | 12:31 PM
marizcal's Avatar
Hi, to all....
Ok... Here is the final update for this thread....
---- Clean the radiator fins.... don't work... looks great complete cleaned but the lights goes on again...
---- Change the sensor .... WORKS..... finally the problem was the trans, temp sensor...
After the change... I take a long fishing trip, about 1 hour of normal road, then 2 hours of offroad road, beach and loose sand.... and the lights does not turns on again....
Thanks, for all your advice and comments... see you around...
Old Aug 28, 2021 | 04:30 AM
Luisli1's Avatar
Default Help to find and replace sensor
Originally Posted by marizcal
Hi, to all....
Hi.
I've same problem now.
Could you please send some pics to find the sensor location and sensor connector and how to replace?
Thanks
