Transmission Won't Shift When Cold
#31
#36
#38
RE: Transmission Won
no... it's supposed to be done in the 30k service and that is it
replacing the filter means dropping the sump which is a hard as the exhaust, and a giant bar are in the way.
Explain the history of service on your car and discomike or spike will recommend either changing it or letting it be
#40
ORIGINAL: paul1454
Do you guys change the filter everytime you do a fluid change?
If you do not know if it has ever been done then do it and then you will know that it has been done.
Changing a filter never hurts anything, not changing it will.
