Transmission write up?
Old Nov 13, 2011 | 08:48 PM
carlos84's Avatar
Default Transmission write up?
After going to JC's British 4x4 here in Englewood CO. I received the news that the Disco is in need of a new transmission. Considering on tackling the issue myself. Does anyone have any good write up's?
Thanks!
Old Nov 13, 2011 | 08:49 PM
Whats wrong with the transmission?
Old Nov 13, 2011 | 08:56 PM
carlos84's Avatar
Will not move when in reverse until 1700-1900 r.p.m.'s, same applies when cold and in drive. Added Lucas as one last hope, it did make the gears shift a lot smoother. Haha ha..
Old Nov 13, 2011 | 08:58 PM
Have you tried changing the filter first?
You can buy the trans filter kit at AutoZone for like $20, takes a half hour to DIY in your drive way.
There is a write up on it in the write up section.
Old Nov 13, 2011 | 08:59 PM
carlos84's Avatar
I also have the Rave Manuel but figured more info couldn't hurt.
Old Nov 13, 2011 | 09:02 PM
Seriously, change the filter before doing anything else, these transmissions are just about bullet proof, they almost never fail.
After you change the filter drive it for a week and then change the fluid again.
Old Nov 13, 2011 | 09:05 PM
carlos84's Avatar
I did change the filter @ 102k and just changed out the fluid but no new filter @ 132k and no difference. Would a filter have that much of an impact? 132 and change is on the odometer now
Old Nov 13, 2011 | 09:11 PM
It could, its cheaper than a transmission, its up to you, but thats what I would do.
Old Nov 13, 2011 | 09:17 PM
carlos84's Avatar
Seems fair seeing as how there's not much info on this issue. Will do that. Thanks !
Old Nov 14, 2011 | 08:54 AM
Carlos, send me your number and lets talk, both about Jeff, his estimate and what other options you have.
