Transmission write up?
Old Nov 14, 2011 | 05:29 PM
coors's Avatar
Originally Posted by carlos84
After going to JC's British 4x4 here in Englewood CO. I received the news that the Disco is in need of a new transmission. Considering on tackling the issue myself. Does anyone have any good write up's?
Thanks!
What do you know about the torque converter. Like Spike said, these trans' are bullet proof. It sounds like a bad torque converter. Try to score a spare/used TC and replace your current one to see if you get reverse.
Old Nov 14, 2011 | 07:47 PM
LR info on electronic ZF tranny - 50 plus pages of fun
File Type: pdf
Old Nov 17, 2011 | 03:33 PM
carlos84's Avatar
I did purchase a used tranny with 99k on it. The truck sat for a week and when I backed out the driveway there was no hesitation, seemed the slipping stopped and went right into reverse /drive until it was driven for about 10 min. then the slipping started up again. Will do a filter change and Hope I maybe a lucky one.
Old Nov 17, 2011 | 08:28 PM
First off starting the engine and then dropping it into any gear straight away and there will be hesitation from the transmission as there is no fluid pressure yet, this is perfectly normal.
Second why anyone would install a used transmission without first changing the filter in it is beyond me because you have no idea when that filter was last changed if ever.
Old Nov 18, 2011 | 09:29 AM
carlos84's Avatar
I have not installed the new transmission, and have posted in previous post that I had the filter changed @ 102k then changed the fluid @132k which the truck now has. As for the hesitation, it occurs until the vehicle reaches 1600-1900 R.P.M's in both drive and reverse. I believe this is not normal. I am going to change the filter in one last effort before swapping out the tranny.
Old Nov 18, 2011 | 09:49 AM
Carlos, call me over the weekend and let me know how it is going.
Old Nov 18, 2011 | 01:06 PM
carlos84's Avatar
Will do. Thanks for the input everyone. If I do the swap, def will take pics.
Old Nov 19, 2011 | 08:53 PM
carlos84's Avatar
"Walk by faith not sight." Spike.. Thanks ! Just finished the filter tranny flush and problem solved. Who woulda thunk it. Sorry everyone for the let down. (No pics)
Thanks, all for the input.
Old Nov 19, 2011 | 09:06 PM
Glad to hear everything worked out.
esaycho
25
Apr 29, 2021 09:25 PM
SteveGT
Jun 24, 2013 01:55 PM
migtr0n
Jul 13, 2007 10:11 PM
DOHC Holliday
Jul 18, 2006 12:07 PM
