Transporting a Disco engine in a Disco
Old Dec 16, 2020 | 04:20 PM
Richard Gallant's Avatar
Default Transporting a Disco engine in a Disco
Hi guys I have purchased a 4.6 and transmission to use as "spares". My plan is to move it in my Disco any thoughts, too heavy generally bad idea or ok ?
Cost is about 500.00 CDN all in
Old Dec 16, 2020 | 04:44 PM
redwhitekat's Avatar
That’s nothing for a disco. You can put 3 engines and 3 trannys in there
Old Dec 16, 2020 | 05:00 PM
Always safer to ask the engine/Trans is a good 1.5 hours away in traffic
Old Dec 16, 2020 | 05:58 PM
Dave03S's Avatar
Shouldn't be a problem.
Old Dec 16, 2020 | 06:29 PM
Extinct's Avatar
I like to use a hitch haul for that duty.
Old Dec 16, 2020 | 11:18 PM
mollusc's Avatar
I'm not sure how much an engine and transmission weigh compared to a person, but you probably wouldn't worry too much about having a couple of passengers.
Old Dec 17, 2020 | 03:00 AM
The Deputy's Avatar
If engine and trans are still assembled, the only issue might be, overall length. Even with the seat folded down, she'll be tight. Me, l'd cut a piece of plywood for the back, to avoid damage to carpet and gather up some old blankets to lay underneath. It seems like, no matter how empty you think the engine is of fluids...some always appear...once it tips on a slightly different angle.
Old Dec 17, 2020 | 08:43 AM
redrover75's Avatar
Default Sure
I had a Mercedes V8 Twin Turbo M278 in mine. A much heavier engine.
I
Old Dec 17, 2020 | 02:26 PM
Thanks everyone the transmission and engine are separate so I am good to go. Not sure where it will live long term but it is in garage for a bit.
Old Dec 19, 2020 | 07:21 PM
Well it is home and in the garage a little tricky getting it out but nothing taking your time in the pouring rain could not sort out It had a cooling issue so I will be tearing it down and parting out the stuff I do not need or want. Transmission sat nicely behind the front seats
Brucecain
Sep 19, 2023 06:39 AM
Mullins.cody
Aug 1, 2021 06:45 PM
rit1267
Apr 12, 2015 07:16 PM
sorbet35
Dec 23, 2013 05:38 PM
Disco Alan
Jul 10, 2006 07:38 PM
