Tricky Dick - Throttle Housing Remove Coolant Flow
Old Dec 12, 2017 | 09:10 PM
Friday Night Disco's Avatar
Default Tricky Dick - Throttle Housing Remove Coolant Flow
So I am doing some searches but, not seeing a write up on bypassing the coolant flow through the throttle housing.
Am I search challenged?
I see some post about simply clamping the lines but, is there a complete removal and bypass walk through
Last edited by Friday Night Disco; Dec 12, 2017 at 09:24 PM. Reason: mamma said knock you out
Old Dec 12, 2017 | 09:39 PM
Best4x4's Avatar
Bypass by blocking the lines with bolts or take a coolant line from the intake manifold to the reservoir. I do the later with 5/16 coolant line & a heatwrap over the line
Old Dec 12, 2017 | 09:43 PM
Can I also physically remove the plate?
Old Dec 12, 2017 | 10:18 PM
Best4x4's Avatar
Yes you can
Old Dec 12, 2017 | 11:04 PM
Do I need to make any adjustments for the lack of the heater plate or just bolt it all back together?
Old Dec 12, 2017 | 11:58 PM
Best4x4's Avatar
Bolt it back up & check throttle cable adjustment
Old Dec 13, 2017 | 07:47 AM
Davis31052's Avatar
If you have all the correct rubber and plastic lines, you can tie the two lines together so that the coolant still flows, just not thru the throttle body heater plate.
Old Dec 13, 2017 | 10:37 AM
Best4x4's Avatar
I’d replace the hard plastic line that gets extremely brittle over time with a new 5/16 coolant line and be done with it. The brittle line to the radiator should also be replaced so you’ll have taken care of 3 possible cooling weak spots.
Old Dec 13, 2017 | 10:49 AM
Thanks for the feedback, will be doing the bypass and replacement of hoses in about a week.
any need for a write up for this?
Old Dec 13, 2017 | 01:02 PM
Best4x4's Avatar
I wouldn’t think so, pretty straight forward, plus “some” people swear your LR will explode without it. I remove em ASAP no question asked from my LR’s.
