Tricky Dick - Throttle Housing Remove Coolant Flow
So I am doing some searches but, not seeing a write up on bypassing the coolant flow through the throttle housing.
Am I search challenged?
I see some post about simply clamping the lines but, is there a complete removal and bypass walk through
Last edited by Friday Night Disco; Dec 12, 2017 at 09:24 PM. Reason: mamma said knock you out
Bolt it back up & check throttle cable adjustment
I’d replace the hard plastic line that gets extremely brittle over time with a new 5/16 coolant line and be done with it. The brittle line to the radiator should also be replaced so you’ll have taken care of 3 possible cooling weak spots.
I wouldn’t think so, pretty straight forward, plus “some” people swear your LR will explode without it. I remove em ASAP no question asked from my LR’s.
