Trouble fueling up the Disco all of a sudden.
The last 3 times I got fuel (different stations) the pump kept on shutting off like the tank was full. Only happened a few times during the previous 2 fill ups, but today it was a real PITA and wound up dribbling fuel down the side of the truck messing around with it.
I went through the RAVE a bit and looked around, but figured I would see if anyone has had that issue before and what happened. I'm figuring a vent for the tank has to be clogged or something on it, but no clue. No other fuel related issues ever (no tank pressurization, no fumes, etc).
Thanks in advance!
Thanks in advance!
This has happened to me a few times as well, but I attribute it to the crappily serviced Phillips 66 nearest my house. That is the ONLY gas station that gives me problems. The other two Phillips 66 stations fill the tank completely, then shut off. Every time. This has been going on for over a year (I only use that station because I forget about the crappy pumps).
Did it twice, once at a brand new Sunoco station and then at a Hess station. Should need to fill up again tomorrow, so we will see. I had this on a beater Jetta Diesel I had and it was a real pain in the butt. It was a vent issue and just wasn't worth it to drop the tank and fix it at that point... but would take me 10 minutes to fill up sometimes. Hopefully this just comes and goes!
Thanks in advance!
Thanks in advance!
DiscoIIBrandon
04-21-2011 10:48 AM
pierce2988
09-04-2010 06:29 PM
