Trouble fueling up the Disco all of a sudden.
Old Jun 17, 2011 | 01:58 PM
Snafu / Disco Fries's Avatar
Default Trouble fueling up the Disco all of a sudden.
The last 3 times I got fuel (different stations) the pump kept on shutting off like the tank was full. Only happened a few times during the previous 2 fill ups, but today it was a real PITA and wound up dribbling fuel down the side of the truck messing around with it.
I went through the RAVE a bit and looked around, but figured I would see if anyone has had that issue before and what happened. I'm figuring a vent for the tank has to be clogged or something on it, but no clue. No other fuel related issues ever (no tank pressurization, no fumes, etc).
Thanks in advance!
Old Jun 17, 2011 | 02:57 PM
RAYMAN975's Avatar
mine does that sometimes on my 03. if the fuel neck isnt square with the truck, it clicks off like its full.if the neck is angled towards the back of the truck, like if i pull up a tiny bit too far past the pump, itll do it. but if i hold it square, it works fine.
Old Jun 17, 2011 | 03:28 PM
yloDiscoII's Avatar
Ditto. Mine will do this randomly, sometime 2-3 fill ups in a row. I've always contributed it to the angle of the fill nozzle, and the more sensitive shut off sensors on the pumps.
Old Jun 17, 2011 | 09:07 PM
lordmorpheus's Avatar
This has happened to me a few times as well, but I attribute it to the crappily serviced Phillips 66 nearest my house. That is the ONLY gas station that gives me problems. The other two Phillips 66 stations fill the tank completely, then shut off. Every time. This has been going on for over a year (I only use that station because I forget about the crappy pumps).
Old Jun 19, 2011 | 11:01 PM
Did it twice, once at a brand new Sunoco station and then at a Hess station. Should need to fill up again tomorrow, so we will see. I had this on a beater Jetta Diesel I had and it was a real pain in the butt. It was a vent issue and just wasn't worth it to drop the tank and fix it at that point... but would take me 10 minutes to fill up sometimes. Hopefully this just comes and goes!
Old Jun 20, 2011 | 08:26 AM
longjon76's Avatar
Thanks in advance!
It's a conspiracy meant to keep you from crapping your pants every time you fill up.
DiscoIIBrandon
Apr 21, 2011 10:48 AM
pierce2988
Sep 4, 2010 06:29 PM
Wanderer
Jan 5, 2010 10:45 PM
Camdisco24
May 9, 2008 10:26 PM
Morgan
Aug 14, 2007 08:15 PM
