TROUBLE RESETTING THE SLABS ECU
Old Aug 30, 2008 | 06:20 PM
ronthepoet's Avatar
Default TROUBLE RESETTING THE SLABS ECU
I've been working on my 02 Disco II SLS. Initially, it had a line leaking on the LR Air Spring line, caused by an over-zealous mechanic stripping the ABS plastic (Mr. MuscleHead!). After this was repaired, I left a line loose on the valve assy and the system was shut down by the ECU. This is an assumption, but follows well as, after giving up on getting it to run (ckng all fuses and relays), I decided to trot down to Auto Zone to get the O rings for the 3 fittings (compressor out, out to left and out to right spring) on my unit, as long as I had it apart. The center (compressor) fitting was in hand to check fit.
Like magic, the assembly started running on the way out of the driveway. I pulled the relay for the compressor to prevent damage to the system for the 2 block trip and went on. When I got back, I finished replacing the o rings, plugged in the relay and nothing happened.
Not knowing what (specifically) I had done that caused the reset, I began pulling fuses, anticipating this had reset the ECU. No matter what I did, or in what combination (all fuses pulled, key turned on and off, pulling the neg bat cable, the SLABS ECU has not reset again.
I've replaced and rebuilt all I can. The compressor runs when I jump out the relay, but the ECU isn't opening the valves to the springs.
How can I reset this thing???
Thanks for your help!
Ron
Do or do Not.
There is no "TRY".
-Master Yoda-
Old Aug 30, 2008 | 07:26 PM
Default RE: TROUBLE RESETTING THE SLABS ECU
Have you tried disconnecting the battery and letting it sit for 30minutes or so?
Old Aug 30, 2008 | 07:46 PM
ronthepoet's Avatar
Trying that now. Will report in 35 minutes.
There are more than 50+ pounds of uranium powering the 50+ satellites currently in orbit.
All orbits decay.
Less than one pound, scattered into the upper atmosphere would kill all living things on this Earth.
"Look, Mommy! A shooting Star!"
Old Aug 30, 2008 | 07:53 PM
See, now thats why I dont have Direct TV.
Old Aug 30, 2008 | 08:23 PM
ronthepoet's Avatar
Okay. To be sure the capacitors had discharged, I turned the key into start before hooking the cables back.
Same result. My butt's still draggin'!
And I use my 52" flat screen only for DVD's. Currently playing is the "Chronicles of Riddick" Trilogy-only $14.88 at Wally World!
Ron
Old Aug 30, 2008 | 08:34 PM
HBO, Netflix, highspeed internet and I Rover, what more do I need? Oh yeah, my wife and kids.
As for the SLABS, I's got's nutin'. Sorry.
Old Aug 30, 2008 | 08:57 PM
ronthepoet's Avatar
Thanks for your help.
Now, go enjoy your family! It's SATURDAY!!!
Remember to be happy and to share your joy, for this is the true gift of Life.
-Ron-
lrjon
Dec 18, 2013 02:52 PM
tbarton
Jul 6, 2013 02:39 PM
Patrick Duffy
Nov 16, 2012 05:17 PM
MarvelVT
Dec 26, 2009 10:29 PM
ronthepoet
Aug 31, 2008 08:12 PM
